Time Clock
Time Clock
My computer Time Clock has started to lose time. Any suggestions as to what might be the cause?
I think it has something to do w/time synchronizing. Has to do with internet time. Not very familiar with it, but you should be able to click on the time and get help w/instructions.
Here's what my computer says: (Windows XP Home Edition)
"Synchronizing your computer clock
If your computer is a member of a domain, your computer clock is probably synchronized automatically by a network time server. If your computer is not a member of a domain, you can synchronize your computer clock with an Internet time server.
If synchronization is enabled, your computer clock is synchronized with an Internet time server once a week. However, if you don't have a continuous Internet connection through a cable modem or DSL modem, the automatic synchronization might not always occur. In that case, you can force an immediate synchronization by clicking the Update Now button on the Internet Time tab in Date and Time in Control Panel. This tab is only available if your computer is not a member of a domain.
If time synchronization fails
When you click the Update Now button, your clock should be synchronized immediately. If it fails, it might be for one of the following reasons:
You are not connected to the Internet. Establish an Internet connection before you attempt to synchronize your clock.
Your personal or network firewall prevents clock synchronization. Most corporate and organizational firewalls will block time synchronization, as do some personal firewalls. Home users should read the firewall documentation for information about unblocking network time protocol (NTP). You should be able to synchronize your clock if you switch to Windows Firewall.
The Internet time server is too busy or is temporarily unavailable. If this is the case, try synchronizing your clock later, or update it manually by double-clicking the clock on the taskbar. You can also try using a different time server.
The time shown on your computer is too different from the current time on the Internet time server. Internet time servers might not synchronize your clock if your computer's time is off by more than 15 hours. To synchronize the time properly, ensure that the date and time settings are set close to your current time in the Date and Time Properties in Control Panel.
Notes
To open Date and Time, click Start, point to Settings, click Control Panel, and then double-click Date and Time.
An Internet time server updates the date set by your computer as well as the time.
The Update Now button is not available unless the Automatically synchronize with an Internet time server check box is selected.
You can change the time on your computer clock manually on the Date & Time tab in Date and Time in Control Panel. You can also open Date and Time by double-clicking the clock on the taskbar. "
Not sure if that would help you.
Notes
Originally Posted by racraft
Another cause of a clock losing time is a failing battery in the computer. How old is the PC and has the battery ever been replaced?
Yes, change out your BIOS battery. It's a very simple task even for the most beginner. Just open your case, and it will be right there on the motherboard. It like a battery in your car alarm remote, etc. Those little silver round batteries.
