built in scanner and camera wizard
Does windows xp have a built in camera and scanner wizard?
What would a person need to type in "Run"
to bring it up assuming it got lost or deleated from the O.S ?
Need to know !
Need to know !
Yes, XP does have a "Wizard" for these two items. I don't see how it would have been deleted or lost, but, when you plug in either of these products, XP will automatically detect it. If not, then you need to install the hardwares drivers and software manually. What is the problem you are having specifically?
deleated icons
I went and deleated the icons(links)
abut i did use system restore to get it all back!
I'm wondering now if I could of typed something in "Run"
to bring it back?
to bring it back?
Originally Posted by HotinOKC
you cant type anything in the "Run" box unless you know the exact program extension name (example: wizard.exe, etc).
scanner wizard
[QUOTE=nashcat]The camera wizard should be in the Control Panel. Click Control Panel/Cameras and Scanners/Add Device.
Nashcat[/QUOTE
Opps you made a mistake there is a differance between camera and scanner wizard and
camera and scanner Instillation wizard
Nashcat[/QUOTE
differance
Isn't there a differance between scanner and camera wizard
and the camera and scanner Instillation wizard...I did do some editing on last post I agreed with previous poster that under scanners and cammera you could find a icon called add image device but this pulls up camera and scanner instillation wizard
not camera and scanner wizard are you confused yet?
