True or False, If you have Firewall protection...
Old 10-12-06, 01:45 AM
E
...such as Norton, windows XP Firewall should be shut off?
Early on, I believe after I installed service pack II, I was told uncheck it for reasons I cannot recall, but by good authority. (could have even been Tae)
Does this still hold true?
Old 10-12-06, 04:29 AM
R
Generally speaking, you should only run one software firewall on a PC. The main reason for this is that they MAY interfere with each other. There is no guarantee that they will not play nicely either, so it;s a gamble.
However, two firewalls does increase the work you need to do to in regards to opening ports, defining rules, etc., and of course it increases the use of system resources.
