boot up issue!!!
Old 10-13-06, 02:26 PM
G
boot up issue!!!
I was given a computer that i thought i could use for my son to play games on but as it seems i can't even get the computer to boot up.... i get a message saying verifying DMI pool data update success ... disk boot failure insert system disk and press enter ... not sure what this means if anyone can tell me if this is serious or something i might be able to correct myself ...
Thanks Gord
Old 10-13-06, 02:39 PM
tae's Avatar
tae
tae is offline
take a look here:
http://www.computerhope.com/issues/ch000474.htm
Old 10-13-06, 04:35 PM
R
Disk boot failure means there is no boot disk. This means that the hard drive is not connected properly or that the hard drive does not contain an operating system.
You need to either connect the hard drive or put an operating system on it.
Old 10-19-06, 04:49 AM
AxlMyk's Avatar
It could also mean the hard drive just plain died..
Old 10-19-06, 05:22 AM
G
I have an extra three different hard drives one that i know for sure has an OS on it ... I tried them all still same message..
Thanks Gord
Old 10-19-06, 06:05 AM
A
do you have a win98 CD or bootup disk?
make one from http://www.bootdisk.com/ for windows 98. it fits on a floppy. boot computer with floppy in system and reformat the hard drive. than load the operating system from 98/2000/xp whatever you want.
post current computer specs to help further
Thanks Gord
Old 10-19-06, 06:07 AM
A
do you how to get in bios?
if so change the setting to boot from hard drive.
the computer may be looking at something else for operating system other than hard drive hence changing hard drive does not make a difference.
Old 10-19-06, 07:42 AM
AxlMyk's Avatar
It's possible the power supply is bad.. Check for 12 and 5 volts on the hard drive plug..
Black-yellow = 12
Black-red = 5
