add/remove
Old 10-14-06, 01:31 PM
P
Received 6 Upvotes on 6 Posts
add/remove
There was a time if you removed Microsoft updates from 'add/remove', some necessary files were also deleted so it was not advisable. What is the case now? Thank you
Old 10-14-06, 06:00 PM
tae's Avatar
tae
tae is offline
http://support.microsoft.com/kb/823836
They must be removed in the opposite order they were installed.
Old 10-15-06, 07:39 AM
P
add/remove
Two quick questions, please - I noticed wen I click the box at the top of the page the updates are all dated and in order.
One question is, what about the Microsoft.net Framework entries above the updates and mixed in with the general population as they are not dated?
Second is, if you want to remove a single entry that is, hypothetically, the fifth from the last installed, you must first remove the 4 entries that were installed after it-correct?
Thank you
