win me
Old 10-29-06, 12:50 PM
P
Received 6 Upvotes on 6 Posts
win me
A friend of mine cannot complete a defrag. I know ME is a horror show but am curious why the defrag says it cannot complete its task. The format reinstall is too much for us so we are going to try to run some a/v programs along with some malware programs. Will the clean up center scan at the Microsoft site work with ME? Thank you
Old 10-29-06, 01:14 PM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
Try these steps. They are for Win98, but try it with ME.
Go to Start > Run
and type msconfig in the Open: box
On the General tab, uncheck all items listed under Selective startup (make sure that Selective startup is selected)
Hit apply and OK and restart Windows
This starts Windows with only the basics running; Insures nothing will interfere with ScanDisk and Defrag
Run ScanDisk and Defrag, when ready go into msconfig and select Normal startup and restart Windows
Old 10-29-06, 03:25 PM
C
Try to defrag in Safe Mode. Upon restarting the computer press F8 and select Safe Mode, then run defrag.
Old 10-29-06, 03:47 PM
mango man's Avatar
Talking
nothing to ad to your problem
but I thought
WIN ME
was a contest
Old 10-29-06, 04:04 PM
H
Wink
Windows ME can be a contest.
Old 10-29-06, 05:53 PM
R
Windows MyEnemy is an abomination. If you have it, replace it. And then never admit you had it.
Old 10-29-06, 06:34 PM
AxlMyk's Avatar
It's possible the hard drive doesn't have enough room to do a defrag.. There has to be enough room for files to be moved around before they get placed where they should be..
Old 10-30-06, 04:33 AM
P
win me
Thanx all, I have made notes and will give it a try -after that I'll advise him to get a Vista capable pc with xp on it - I like xp even with all its patches.
Old 10-30-06, 07:53 AM
A
running anti virus in the background may be causing this issue
turn them off and try again.
Old 10-30-06, 08:27 AM
P
Me
I'll give it a try + thanx.
Old 11-02-06, 09:50 AM
P
disk space
We tried in safe mode with no success but wanted you to know when we removed some programs to make more space on the disk as you said, it did defrag in safe mode -thank you.
Old 11-02-06, 12:54 PM
AxlMyk's Avatar
I've had that happen to me..
YW
Old 11-02-06, 02:41 PM
A
could you post what program was removed.
it may be the program and not space issue. it would be good tp check this theory in case someone else has enough space but the program is interfering.
Old 11-03-06, 04:58 AM
P
defrag
That's a good idea and thank you.
