printer spooler service not running???
Old 12-02-06, 09:08 AM
7
i tried to print something and it says i need to install a printer??? did not realize it had been deleted...anyways when i try to reinstall i get the message "printer spooler service not running", what does that mean? anyone know how i can fix this??
Old 12-02-06, 09:33 AM
AxlMyk's Avatar
Using XP? Try this..
Start-settings-control panel
Administrative Tools - Services
Scroll down to Print spooler
Right click - properties
Path to executible should say x:\WINDOWS\system32\spoolsv.exe
Startup type should say Automatic..
If it isn't started - start it..
Old 12-02-06, 12:16 PM
7
printer spooler
thanks a million, this was disabled. also, when i went to this it told me that plug n play service or another required service was not available. i saw that my plug n play is also disabled, do i want this to be auto. also? once i put printer spooler to aotu. it is letting me print, just curious about this plug n play now. thank you.
Old 12-02-06, 12:33 PM
R
Print spooling is not necessarily required. I suppose that some printer drivers may require it, but not all of them. Print spooling simply means that the job to be printed is saved on the hard drive and then sent to the printer as the printer can handle it. In the mean time, the computer program (such as Word) can go on and do other things, including being terminated. Without spooling, the job is sent to the printer a little bit at a time by the program, and the program cannot be terminated and will respond slower because it taking time (periodically) to service the printer.
Plug n play is not required. Without it you will have to manually tell the computer about any devices you add, such as drives, cameras, etc.
Old 12-02-06, 01:37 PM
AxlMyk's Avatar
Sure.. Go ahead and enable P&P..
