hard drive info
Old 12-03-06, 05:20 AM
daswede's Avatar
hard drive info
I have a,what i think,is a 40 gb hard drive in my computer.
I opened my 'system' window,but i don't see a reference to a hard drive.
Is there some way of determining what size this drive is?
Thanks
Old 12-03-06, 05:52 AM
R
What operating system do you have?
If you open a Windows Explorer window you can find the properties of a drive. Find the drive in "Folders" pane. Then right click on the drive and select Properties. It will tell you more than you want to know.
You can also find additional answers to this question by using Windows Help. In fact, just about all your questions can be answered using help. Microsoft wrote the help screen to allow people to answer their own questions.
Old 12-03-06, 05:55 AM
daswede's Avatar
Thanks. I will check that out
daswede.
Follow up:
I just found the info i needed. Much obliged!!
Old 12-03-06, 08:41 AM
AxlMyk's Avatar
My Computer - then right click on the drive letter - properties..
Also, look in the BIOS when the machine starts up..
There are times when OEMs will create a seperate partition that holds the files for re-installing the OS, so the total size available to you will be reduced..
Old 12-03-06, 08:44 AM
daswede's Avatar
Thank You. Another good source.
Old 12-03-06, 09:38 AM
william tell's Avatar
Just curious, why do you want this info ?
Old 12-03-06, 09:57 AM
daswede's Avatar
I was given a computer. I was able to determine the components of the system with the exception of the hard drive. I thought it strange that i couldn't find out what the harddrive specs. were.
Old 12-04-06, 05:13 AM
daswede's Avatar
Follow up:
I found the info from all the posted means that everybody replied to.
I must have been brain dead in not being able to find the info.
Thanks again.
daswede
