H.P. camera/computer upload issue
Old 12-30-06, 01:48 PM
daswede's Avatar
I have been uploading pictures from my HP photosmart 720 camera to my computer using H.P.'s software for a couple years.
Yesterday i did my normal upload of Christmas pics and when i went to look at them in 'my pictures' folder they weren't there as usual. I finally found them in my documents folder so they were loaded into my computer.
I have been scratching my head as to what has changed,but can't come up with anything. My wife uses the same computer with the same camera software and her pictures end up in the 'my pictures' folder as usual. Of,yeah, i contacted H.P. support,but the support tech. wasn't any help.
I'm obviously missing something and thought i'd run this by the knowledgible folks here.
So far iv'e checked my wife's settings,same as mine. uninstalled/installed the software.
Thanks for any suggestions.
Old 12-30-06, 02:11 PM
HotxxxxxxxOKC's Avatar
You probably need to set the "destination folder" in the options portion of your camera program.
Old 12-30-06, 03:04 PM
daswede's Avatar
Unfortunetly there is no option for that in the camera itself. only choices on the camera is USB,or Disk. I'm using USB
Old 12-30-06, 04:07 PM
When you opt to save the photographs, there is no dialogue box in which to select the destination? You might try renaming the current folder to something else, then trying it again. When the named folder is not found, some sort of dialogue box should open.
Old 12-30-06, 04:35 PM
I was not refering to a setting in the actual camera, but there should be a HP photo program on your machine that this needs to be adjusted in.
Old 12-30-06, 04:54 PM
daswede's Avatar
Thanks Chris and mark for your reply.
I'll look into your suggestions some more,and if i
can't figure out the problem ,I'll just go into my documents folder to
work out of.
Happy New year
daswede
Old 01-16-07, 11:33 AM
daswede's Avatar
My apologies for not replying sooner. The folder got misplaced.
Thanks for your help
