LCD Monitor & Sharing?
Old 12-31-06, 01:08 AM
I have a Viewsonic VA712B LCD monitor with both DVI and VGA ports.
What would happen if I were to connect one computer to the DVI port and another computer to the VGA port at the same time?
The LCD manual does not say whether the monitor would be able to "switch" between the two inputs.
Thanks.
Old 12-31-06, 07:17 AM
I suspect that when a signal is applied to both ports that the VGA port would win.
But why would you try this? Buy a KVM switch and do this properly.
Old 12-31-06, 07:23 AM
AxlMyk's Avatar
I wouldn't want to take the chance of burning something up.. Whether it be the monitor, or video card..
Old 12-31-06, 09:01 AM
Received 84 Votes on 77 Posts
I don't see why it wouldn't work. You should simply need to switch which port the monitor is using from your monitor controls.
Old 12-31-06, 10:59 AM
It should work, because
On the LCD monitor I have you have to go into the LCD monitors Menu to choose which input to use. Don't know if that's the same for all LCD's
Old 12-31-06, 04:02 PM
Pendragon's Avatar
Received 1 Vote on 1 Post
As long as the monitor has an easy method for switching inputs, it'll work.
While this lets you see the other monitor, which is fine if you just need to see if it's running, a KVM switch would give you actual access to the machine.
