Add hard drive
Old 01-06-07, 09:45 AM
Add hard drive
What do I need to know about a computer to buy a compatible internal hard drive? I.e., what info do I need to bring to the store?
Old 01-06-07, 10:19 AM
the_tow_guy's Avatar
Received 38 Votes on 30 Posts
Just the maximum size your motherboard/bios will support. Some older machines may not be able to take a huge hard drive without some tweaking. Other than that, if you have a manual for the computer it should have the pertinent specs in it.
This is an PC rather than an Apple, I'm guessing?
Old 01-06-07, 10:27 AM
AxlMyk's Avatar
If you are keeping the old drive in the machine, there are a couple things to do..
One drive must be set as MASTER w/slave, and the other as SLAVE.. There are shorting pins on the drives to do this.. Master being the boot drive with the OS on it..
You could also set the pins to CS (cable select).. In that case, the drive on the end of the cable will be the Master, or boot drive, and the other will be the Slave..
After you finish installing the drive, as single or dual drives, boot to the BIOS to make sure it sees the new drive.. You might have to tell the BIOS to search for drives to do this, but many newer machines will see them automatically..
Old 01-06-07, 10:50 AM
HotxxxxxxxOKC's Avatar
Also, see if your motherboard has SATA capabilities.
Old 01-06-07, 02:28 PM
Received 57 Votes on 54 Posts
Not a bad idea to have the tower along as well if the store employees handle any details of installation, as you made need cables or a rack to put the new drive on (I needed both).
Old 01-06-07, 05:40 PM
It's a PC, a Dell, bought in the last 2-3 years.
Old 01-07-07, 11:05 AM
HD bad or just upgrading to a bigger one?
Old 01-07-07, 02:13 PM
Huh. I assumed you were adding another hard drive. TG's post has me wondering whether you're replacing instead.
Old 01-07-07, 02:25 PM
AxlMyk's Avatar
He hasn't said..
Old 01-07-07, 04:18 PM
Hmm, maybe I got fooled; I was assuming replacement.
Old 01-07-07, 07:36 PM
Sorry, not a replacement - an additional drive in an empty bay.
Old 01-08-07, 06:54 AM
OK. I stand by my original post, except that with a Dell, I believe your odds of already having everything you need inside the computer are better than mine were.
Old 01-08-07, 11:24 AM
My bust; should have noted the word "Add" in the original post.
Old 01-08-07, 05:25 PM
tae's Avatar
tae
tae is offline
you need to know if it's IDE, SATA, or SCSI, and which type is available on your motherboard. Consult your documentation or Dell to see which you need/can have.
Old 01-10-07, 05:38 PM
Better off getting an external HD. No installation worries & you don't lose it when you get a new computer.
Old 01-10-07, 07:17 PM
Add hard drive
If you buy a hard drive, buy a big one since the cost difference in not that much. You may want your new drive to be the master and larger than your old or vice-versa.
My mother board died and I was forced to buy a new desktop computer. The old 175 GB with data just went into the new computer with a 200 GB drive. - Have a lot of graphics!! It sure is a luxury and I use it as a secondary back-up that I back up frequently between major back-ups that I store separately.
Dick
