DSL Modem 2 ethernet cables out of DSL BOX? QUESTIONS????
Old 01-20-07, 02:52 PM
diyplank's Avatar
Received 1 Vote on 1 Post
Didn't know how else to post the title, so here it goes. My brother moved in w/ my wife and I until summer and he needs internet. I have verizon DSL in my computer room and his computer is literally 15 ft. from my computer. I know there are wireless modems you can buy for a desktop but he would like to have the same speed as my DSL. He has a cable that will reach that far but how do I go about hooking it up. Is it like a plug and play kinda deal or is there a set up I have to do. Does he have to have the verizon program on his computer as well?? Is there going to be a set up for networking or is that only for sharing files from computer to computer, which we aren't going to be doing?. Thanks in advance!!
Old 01-20-07, 03:04 PM
mango man's Avatar
buy a router , 40 - 50 dollars
dsl modem to router , your pc to router his pc to router .
he doesnt need the verizon program
Old 01-20-07, 03:10 PM
diyplank's Avatar
I have a Westell DSL Router. Has the little antenna on the top and everything. Has 3 other empty ethernet cable ports on the back. So I can just go ahead and plug it up to his computer?? What about setting up an internet connection on his computer. I would need to do that right?? Thanks
Old 01-20-07, 03:16 PM
mango man's Avatar
sure plug into the switch port on the router , when he restarts his computer the modem/router will assign a Ip address and he should be online .
shouldnt be a need to set anything up
if that doesnt work he may have to do some set up
post back with what OS and someone can help
Old 01-20-07, 03:22 PM
diyplank's Avatar
OK THANKS I am going to run the line in a couple of minutes. We both have dell computers and both have XP!! I will post back when I get it done. What if he wants to print something using my printer?? He don't have one and I figured why buy one if he can just use mine?? I know you can get cheap ones but he is a college student so. THANKS AGAIN!!!!
Old 01-20-07, 03:30 PM
mango man's Avatar
your PC
start
printers faxs
right click on the printer
sharing
share the printer
he goes to
start printers
add printer
add network printer
it will search and should find your printer
your pc will need to be on for him to print
Old 01-20-07, 03:44 PM
diyplank's Avatar
OK, plugged it in my dsl router, plugged the other end of cable to his computer, started it up and I opened IE and nothing. I went to the control panel and opened the modem icon and went to properties and it is sending ok, just not recieving. He has a ethernet port but it looks like the only one installed is the standard 56k modem that comes w/ the computer. So some how I need to get the driver or get the computer to recognize the ethernet card. I am going back over to work on it a little. THANKS
Old 01-20-07, 03:53 PM
mango man's Avatar
go to tools
internet options
connections
never dial a connection
(you might have to also install TCP/IP)
Old 01-20-07, 03:58 PM
diyplank's Avatar
Ok got it!! I had to set up a new connection. I picked broadband and I had to type in my login info(user/pass) to get it to connect. I have since unplugged the wire so until he gets about a 10ft longer cable he will have to unplug and plug it in when he wants to use it. Thanks so much for your help!! Chris
