My IE window is real small on startup!!
Old 02-26-07, 04:53 PM
fatkid66's Avatar
Kind of a minor problem, but the window used to open up almost full screen at one time, but now its real small on startup and i have to resize....kinda minor, but its annoying...Any ideas how to fix this??
Thanks in advance!!
Old 02-26-07, 06:00 PM
chandler's Avatar
Received 5 Votes on 5 Posts
Once it comes up, take your cursor and drag and drop the corners to maximize the screen in all directions. Then close IE. It should remember the sizing from then on. Let us know if you succeed or if we need to drop back and punt.
Old 02-26-07, 07:32 PM
T
as said above... that always works for me
Old 02-27-07, 06:50 AM
fatkid66's Avatar
Ill give that a try tonite and let ya know!!! Thanks!!
Old 03-05-07, 12:14 PM
I have the same problem as the OP, every time I open IE7 (XP pro SP2) the window opens small. I've resized it many times and it still opens small. Even programs open in a small window, forcing me to open it to full size.
Old 03-05-07, 04:19 PM
tae's Avatar
tae
tae is offline
Internet Explorer opens as a small window
1. Open a link.
2. Don't use the maximize button.
3. Stretch the corners so that the window fills the screen.
4. Close all other IE windows.
5. Close the stretched window last.
OR:
Close all browser windows.
Open a single incident of IE - a single tab only - and resize it the way you want. Then close it.
When you reopen, it should be where you last left it.
If not, repeat the above, but close the window specifically by holding down the Ctrl key and clicking the X in the upper right corner.
And: do not forget to run a malware scan and an antivirus scan.
Old 03-06-07, 08:24 AM
Thanks Tae, I will try it tonight and let you know how it went.
Old 03-12-07, 09:58 AM
No worky tae, any other suggestions ? If it involves modding the registry I'm getting scared.
Old 03-12-07, 11:31 AM
AxlMyk's Avatar
Press the SHIFT key while you resize the window..
