Wireless won't turn on
Received 0 Votes
Trying to fix an Averatec 5100 for a friend , it runs XP pro. When turning on the wireless switch , nothing . problem is it did work before. Is it possible this may be a software issue? If not has anyone experienced a similar problem and found a fix? Thanks.
Laptops with built in antennae or PCMCIA antennae connect automatically to WiFi locations, so I am at a loss to understand why a physical on/off switch is needed. And I do hope the matters the moderator expunged weren't aimed at us.
I don't think the problem is with the switch. Simply turning the switch to ON, does not mean that your laptop will automatically connect to a wireless network. You need to make sure the correct drivers are installed for the wireless card, and then you need to actually make a connection to a network. Normally, you would click on the wireless network icon that appears in the system tray and enter the appropriate information (SSID, security key, etc). Normally if I turn my wireless switch to OFF and then back ON, it will automatically reconnect... but not always.
