changing Icons
Old 05-24-07, 08:16 PM
Question changing Icons
How do I change an icon that is associated with a file? I have a movie file that opens with quicktime, but the icon is of the real player. I want to change the icon, but do not know how.
Old 05-24-07, 08:26 PM
HotxxxxxxxOKC's Avatar
Right mouse click the icon
then go down to properties
then select "open with"
Old 05-25-07, 04:27 AM
You don't change the icon.
What you change is the file association. Windows allows all file types to be associated with an executable so that when you double click the file in an explorer window it will open.
You can, as has been suggested, right click and then select "Open With", but that may not necessarily make the change permanent. To make the change permanent you select "Folder Options" from the "Tools" menu in Windows Explorer. Then select the "File Types" tab. Scroll to find the particular file type (or specify one that is not in the list) and then change or specify the file (program) to be used to open the file.
Old 05-25-07, 05:51 PM
I have done the open with and the file types and neither one changes the icon.
Old 05-25-07, 07:06 PM
The icon doesn't mean anything, but it's possible it stored in the file itself.
Old 05-25-07, 08:14 PM
tae's Avatar
tae
tae is offline
if you right click it, and go to properties, on one of the tabs there should be a button that says...change icon...
Old 05-27-07, 02:41 PM
I found that, but it is for the folder icon, not the file itself. In anycase I have removed the media programs that I use (realplayer and quicktime) and installed quicktime first, set the correct Icon and program and then installed the other program and it worked. All that work for a icon, shish.
Old 05-27-07, 04:19 PM
I think you could have gone into Quicktime and set it as your default media program. This should have changed all the icons.
