Switch computer automaticly
Old 06-09-07, 08:05 AM
Hi, can anybody tell me if it is possible to schedule your computer to switch on automatically? Once i heard that you can do this from the bios, but i dont know.
Thankx and regards
Christian
Old 06-09-07, 08:13 AM
..ummm, why would u want it to turn on automatically? Theres settings if you want certain devices to "turn it on" or but dont now bout a hard start-up or turn on off the top of my head. G/l
Old 06-09-07, 09:05 AM
AxlMyk's Avatar
You need to go into your BIOS settings to see if it will do what you want..
Old 06-09-07, 11:26 PM
Pendragon's Avatar
Received 2 Votes on 2 Posts
Even if your BIOS does not have that option, it probably has a 'on after power fail' option. This option, when enabled, will turn the computer on after a power failure.
So, just set a scheduled time to shut down, and use a wall timer to re-apply power at the time you want it to come back on.
Old 06-10-07, 06:09 AM
I have never seen a BIOS that allows you to schedule a power on...that is not to say that it does not exist. As for using a wall timer to schedule a power on...if you shut down your computer using the shutdown command the power on after power failure feature of the BIOS will most likely not power the machine back on when the timer kicks in.
Is there a specific reason why you want the power to be powered on at a specific time?
Kevin
Old 06-10-07, 08:42 AM
Pendragon's Avatar
The power on after power failure will turn the machine back on regardless of what method was used to turn it off with, be it shut down, hibernate, etc. It merely reapplies power, it doesn't know or care how it was shut down (if at all).
Old 06-16-07, 09:44 PM
I know if it's a Dell, there is a power on feature. You will find it in the bios.
