format help
Old 06-11-07, 02:52 PM
format help
hi.......
i am reinstalling the operating system on my laptop due to some problems ive been having. i formated one of the partitions no problem but when i went to format the main drive i kept getting an error message saying "cant format the drive, please close all running programs and try again" I did this, even started it up in safe mode and i still keep getting this message. Anybody got any suggestions?????? toshiba notebook,, xp operating system....
thanks scanner....
Old 06-11-07, 03:12 PM
AxlMyk's Avatar
That's because you are using that partition and the OS doesn't want to destroy itself..
Old 06-11-07, 10:47 PM
You said u deleted one of the partions. If thats the one you were having problems with why would you want to delete the "main" partition. As far as I know you cant format the same partition that is active. Theres many o ways to do it but why not repair it?
Old 06-12-07, 05:31 AM
You cannot format the main partition unless you boot from the CD (or some other source).
Old 06-12-07, 07:18 AM
thanks racraft
booted from cd as u said.......problem solved
thanks..scanner
Old 06-12-07, 11:46 AM
Is this windows XP?., if so you must restart the laptop with the windows XP disc in the drive, and when it detects the Disc, you must hit a key for it to bootup into a blue type of Dos rather the old black screen in Dos.
Then follow the prompts to format Drive C.
