Cable Modem and multiple PCs
Is it possible to use one modem for two PCs. Using either a y adaptor for the ethernet connection or just disconnecting one when not in use?
You could disconnect one and connect the other or you could do it right with a simple router ($40 to $80).
one note of caution; if you have a scanner or a printer or other peripherals, you need to do one of several things to be able to use them with each computer.
If they are connected to one particular computer, you would need that computer on anytime you wanted to use the peripherals.
This can be avoided if the peripherals utilize a "server" board within them. Then, they become autonomous and are simply connected to the network router and can be used by any computer so connected as well regardless of the status of the other computers on the network.
A printer server can also be purchased to allow multiple users if the peripherals do not come equipped OE for that purpose.
yes, but what a pain Mango. I did this for awhile and grew tired of it very quickly. A router is not very expensive (mine is a wireless/wired combo and cost $40 on sale from $50)
as well, if there are peripherals involved, that changes the picture regarding ease of changing.
I don't think a y-adapter will work. (I've never seen one either for an ethernet cord)
You'll need a router unless you only hook one computer up at a time.
The router will plug into your cable modem, and it'll have 4 or 5 spots to add computers to it.
