Mix & Match RAM?
Old 09-04-07, 01:15 PM
E
Mix & Match RAM?
I'm planning to replace my 2 x 256 mb chips with a 1 GB stick. I have only 2 slots. Can I leave 1 of the 256 chips in place?
The ram is all DDR, PC 333 mhz.
eMachine H2642 (maximum 2 GB ram)
Windows XP Pro
Old 09-04-07, 01:24 PM
Received 300 Votes on 266 Posts
I added a 512mb along with my original 128mb and had no problems - was pleasently suprised at how much better my pc worked
You might need to check and make sure you don't excede the RAM that your pc can use, mine has a 1gb maximum.
Old 09-04-07, 03:07 PM
E
As far as I have read, I can run 2 GB. I remember running odd pairings in the 'old days' (2-3 years ago?) but that was with DIMM chips. No harm in trying I guess?
Old 09-05-07, 05:48 AM
for what's worth
Both of my chips are DDR SDRAM.
Old 09-05-07, 06:40 AM
AxlMyk's Avatar
You can try it.. Run memtest86 to make sure it will work without errors..
www.memtest.org
Old 09-05-07, 04:02 PM
E
"Both of my chips are DDR SDRAM."
OK, I'm going to give it a try as soon as the chip arrives (on backorder).
Thanks mark
Also, thanks Axl for the tip on memtest86. After doing a bit of surfing, I found a memtest86+ (a 2007 version). Looks like a handy tool to have.
Old 09-07-07, 04:53 PM
E
Just thought I would update everyone ...
... the new chip arrived today ... popped out the first 256 chip, replaced it with the new 1 GB ... I now have 1,256 mb of ram!
First try! No 'beep beep beep'.
I love it when things work out perfect
Thanks Axl (again) & Mark
