hard drive partition
Old 12-30-07, 09:30 AM
CMil's Avatar
please help! I've installed a used 10GB Western Digital hard drive in my homebuilt computer. When I power up, I am prompted to choose between Windows XP (which I installed and always select) and Windows 2000 pro (which was on the drive when I acquired it). And when XP starts, I only have about 4GB on the drive. How can I clean off and remove the 2000 partition and restore that space so I can use it? It doesn't seem to take very much to fill up 4 gigs anymore! I would appreciate any/all help. Thanks in advance - Chris
Old 12-30-07, 11:29 AM
R
Someone was very foolish to give you a drive with anything on it. But that's another issue.
Repartition the hard drive the way you want it, then reformat it and install the operating system you have a license for.
Old 12-30-07, 10:00 PM
C
I agree with the above poster, as if you attempt to delete the windows 2k partition you are going to remove windows boot loader and your system will not know that the XP partition exists... it will not boot.
Old 12-31-07, 07:11 AM
CMil's Avatar
Thanks, guys. I've had computers in the past that if you hit the F4 key during start-up, you would be directed to the command prompt (?). At that point you could type in "fdisk" and get access to mess with disk partitions and such. This computer only gets me the command prompt in safe mode, then it doesn't recognize "fdisk" as a valid command. Any ideas? Again, thanks for the help so far. Hope to hear from you soon - Chris
Old 12-31-07, 07:15 AM
R
You need to boot from a different source. Boot from the Windows install CD, a floppy disk with an OS on it, or some other source.
Old 12-31-07, 07:19 AM
CMil's Avatar
Thanks, Bob. Going offline to try it now.
Old 12-31-07, 09:21 AM
CMil's Avatar
COOL! Got a fresh install of xp and a 10GB hard drive. Thanks, Bob!
