HP Deskjet 960 prints junk
Old 05-06-08, 11:17 PM
D
Somehow I got my HP Deskjet Printer 960 into printing page after page of junk. Each page had only a line or two or random characters. I don't remember what I did, but it finally finished the junk job and is performing ok.
Does anyone have an explaination for this?
If this should happen again, what can I do to get out of this mode?
Thanks.
Old 05-06-08, 11:57 PM
T
1) cancel the print job
2) disconnect the printer from the computer
3) turn the printer off
4) put a half dozen sheets of paper in the printer
5) turn the printer back on
6) let it print away (replacing the same paper over and over) until it finally decides it has done its job and stops.
For additional info on garbled printing: http://h20000.www2.hp.com/bizsupport...ectID=bpj06309
Old 05-07-08, 11:09 AM
HP printers are reset to factory default by turning off the
printer-pull the elect. cord at back of printer--wait about a minute--plug back in & turn on printer.
Were you printing something off the web when you got all these extra pages ?
Old 05-07-08, 07:54 PM
D
I remember turning the printer off, then back on. The printer just resumed printing that junk. So I just recycled the printed pages until it was done. It seemed like at least 30 pages of useless stuff. Probably was printing something off the web.
Good info on the link twelvepole.
Doesn't turning the power off or unplugging the power cord achieve the same thing?
Old 05-09-08, 08:29 AM
A
I've had that happen a few times. It happens when I try to cancel a print job. I get around it by turning off the printer.
Old 05-09-08, 03:13 PM
HotxxxxxxxOKC's Avatar
I would also install a new driver. Often times the driver will get corrupted.
Old 05-09-08, 06:58 PM
B
pulling plug
Dave;
I am not a real hotshot computer expert, but I believe that just turning off is not the same. To reset to default ALL power must be removed. The computers and associated equipment will still continue to daw "trickle" voltage to maintain settings. The only way to remove is to completely remove the power source. Just like resetting a cable modem or wireless.
Old 05-10-08, 06:30 AM
C
I think this is the problem. I have services countless printers and if your getting random characters it is a hallmark of driver corruption...
Go to hp.com select support. Type in your model and grab the latest driver package (get full software if avail so it will have the hp utilities)
Delete printer, and run the setup program from what you downloaded and the printer will be reinstalled with the latest drivers.
Also you can check windowsupdate to see if they have a better driver there as well.
Old 05-11-08, 05:42 AM
H
The information sent to the printer from the computer is a series of codes followed by data for the code. For example, there is a code that says the next so many bytes of data following is for a graphic. The actual graphic data is binary which means it can contain any type of character including some that actually print (the garbage) and others that tell the printer to eject a page. Normally the data is treated as a graphic, prints properly, and then the next code is read.
What can happen though is the communications to the printer gets interrupted (driver or other problem) so that the code part gets lost and the binary data is printed as if it were text. This results in the many page ejects and garbage being printed.
Old 05-11-08, 06:15 AM
O
Usually not.
harvx got it right.
Old 05-11-08, 09:01 AM
Originally Posted by oneofamill View Post
Usually not.
harvx got it right.
Read his post, he said driver as well......
Old 05-11-08, 11:13 AM
My buddy gave me a neat program--by Epson called " web-to-page " when you are printing something on the web-you click on print preview & it shows each page that will be sent to printer. Uncheck any page that you do not want printed &
it will not print. What a paper & ink saver.................
