APC Back-UPS Office 500 VA
Yesterday the power went out for maybe one second and came back on.
Instead of running off the UPS the computer and monitor shut off. Received a steady alarm and yellow light (battery running low) for about a minute then the red light (replace battery) came on and the UPS shut down.
Hmmm.....always worked correctly before, why not now? And seeing the power was only off for a second, why didn't it switch back to line power?
I bought the UPS in 01 so the battery is getting old but no low battery warning or anything like that.
Very confusing, any ideas?
Thanks,
Baldwin
Thanks,
Baldwin
You got 7 years out of that battery, so I'd say it did well.
If you are running the powerchute software, it ran a self test every week. If you aren't, then it never tested the battery under load.
"If you aren't, then it never tested the battery under load."
OHHH....I didn't know that. No, I didn't run the software because I always turned the computer off when I left and didn't think I needed it. Learn something every day.
I see a new battery is around $54 or I can trade this UPS in for a new one, 550 VA, for $56 with two more outlets. I think I'll go that route.
And I will run the software this time.
Thank you!
Baldwin
Thank you!
Baldwin
