computer,or window's problem
Old 11-08-08, 09:46 AM
daswede's Avatar
Some sites i can open o.k. while others,including this one,take forever to load.
I've done a defrag,disc cleanup,run ad aware,and Mcafee antivirus. Have 79% disc space.
I don't have a complaint with slow running,just slow loading.
Any thoughts?
Thanks
Old 11-08-08, 11:09 AM
HotxxxxxxxOKC's Avatar
Have you called your cable provider?
They can check your signal and packet loss information to see if it's a problem on their end.
Are you using a wireless router?
Old 11-08-08, 01:59 PM
daswede's Avatar
I'm using Verizon broadband. Only connect is from modem to computer.
I guess i'm leaning to some of those sites i open because not all sites i visit load like that. Other's load like a bullet.
Its not really a show stopper,just pain some times.
Thanks for the reply
Old 11-08-08, 02:17 PM
crazycory22's Avatar
Received 1 Vote on 1 Post
have you tried resetting your modem? i used to have verizon dsl and resetting the modem would sometimes help.
Old 11-08-08, 04:08 PM
Pendragon's Avatar
Received 2 Votes on 2 Posts
You would need to do what's called a traceroute.
This 'traces' all the steps between your machine the machine you are trying to reach. The sites that load quickly probably have a shorter path and less latency than the sites that don't. There is absolutely nothing you can do about the route.
Open up a DOS window (Start > Run > CMD)
and type "tracert www.doityourself.com" (or whatever website you are trying to reach.
A quick run on my end makes it to hop 10 with about 400ms combined latency and then it starts timing out.
A route to Yahoo! makes it in only 8 hops with a total of about 170ms latency.
Old 11-08-08, 06:14 PM
B
This may be a simple solution that is easy to try. I was having the same problem more or less.
If you are using Internet Explorer for your browser try downloading Firefox or Google Chrome, I switched to Firefox and it made a huge difference.
Old 11-10-08, 07:41 AM
T
Look through your add/remove programs in the control panel and remove any thing with the words "search assistant" or "toolbar" in it.
