25" Monitor
Old 02-27-09, 07:06 PM
25" Monitor
I recently received a 25" monitor as a gift.
Some webpages like MSN load in the middle of the screen but this site for instance does not.
Is ther some way to make this happen?
Thank you
Old 02-28-09, 05:24 AM
diyplank's Avatar
Not sure what you mean by not loading into the center? Do you mean the whole picture does not take up the whole screen? Is there black around the picture kinda like a widescreen movie?? If so there should be buttons on the front of the monitor that you can adjust the height and width of the picture. Try that.
Old 02-28-09, 07:57 AM
It all depends on your browser and operating system but here are a few things try..
Have you tried making the text larger?
Have you tried changing source or text layout? Some browsers allow you to adjust some settings so you can change how the browser displays items.
You could also change some of the display settings to change the pixel counts in your browser to see if that helps.
I assume that you have Windows and it is set to something huge like 2xxx by 1xxx. There might be a way you could switch to a lower resolution while you browse it bothers you that much.
