"Limited or No Connectivity"
Old 03-03-09, 05:51 PM
LitUp's Avatar
Yep....The little exclamation point by the network icon has reared it's ugly head.
Called cable company, checked modem....all OK there. Router is OK, as all machines EXCEPT one can connect, and kids video-games can go "online".
Traded cables...no good. Switched router ports...no good.
I'm thinking network card or it's driver. Is there a way to check this...IPCONFIG or IPRENEW or PING or something?? Or do I call GeekSquad or equvalent??
Windows XP home...Lynksis router....cable modem comcast supplied....
Thanks in advance...
Old 03-03-09, 06:35 PM
HotxxxxxxxOKC's Avatar
Go to:
Start
Run
Type in CMD
type in ping 192.168.1.1
If it comes back saying it lost packets, you are having a problem connecting to the router. If it comes back saying it didn't lose packets, it's more then likely a network driver issue.
Old 03-03-09, 08:41 PM
C
Also...are these all connected by wireless? ..by wired?
All computers XP? ..Vista?
I ask because Vista was/is notorious for not liking routers. Believe me when I say I despise Vista with a passion after my experience of fighting with it about routers.
Old 03-04-09, 04:17 AM
LitUp's Avatar
crabbyman
Other 2 computers are wireless, both X-Boxes are hard wired. These all connect fine
Other 2 computers AND affected desktop are all XP Home
HotinOKC
Am trying Command line string soon as everybody gets outta the house for work/school
Thanks to you both.
Old 03-04-09, 08:53 AM
T
It's not super clear, but I'm assuming the affected machine is wired, since you said you swapped the cable. If that's the case, there are only a few things it can be considering the other machines are working fine and you've tried different ports on the router.
To start off, see if you're getting a link light on your machine and on the router. Just look at the port on the back of the machine where the cable plugs in, it should have a little light by it. If you don't have lights, report back on here.
Next, click on the start button, go to run, type cmd. In the command box type ipconfig and hit enter. I'm assuming this will show a 169.x.x.x address, this is what it gets when it doesn't get an address via dhcp from the router. You can try ipconfig /release, then ipconfig /renew and see if it gets an address.
The next step would be to uninstall the network card through device manager. Right click on the my computer icon and go to properties. Click on the hardware tab, then device manager. Look down the list til you see network adapters, double click that. Right click on the one that is your network adapter and hit uninstall. close all the boxes and reboot the machine. If you still don't get an address, there is a possibility that your network card is bad, which is actually a pretty easy fix.
Old 03-08-09, 09:16 AM
LitUp's Avatar
Toofer:
Girlfriend bought network card, it came with CD for installation.
However...NOW I got CD-Rom issues in that the CD drive isnt seen by the computer in "My Computer" (I guess this has been goobered for awhile but i had been blissfully unaware). Message pops up saying: Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
So I cant load the *&^%$#@ driver for the network card. GRRRR!!!!!!!!!!!!!!!!
So now I'm chasing me tail trying get the CDROM to work.
Found an article on another forum suggesting registry modification, tried that but to no avail.
Registry string is:
<TT itxtvisited="1">HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}...</TT>
<TT itxtvisited="1">suggested fix is to delete "UpperFilters" and "Lower Filters".</TT>
<TT itxtvisited="1">This is a new one on me</TT>
<TT itxtvisited="1"></TT>
<TT itxtvisited="1">Am fighting temptation to fix with sledgehammer!!</TT>
<TT itxtvisited="1">Anyone have any ideas?? Thanks in advance, and for all prior tips......</TT>
Old 03-08-09, 11:24 AM
T
can you go into control panel/add-remove hardware and remove/uninstall the network card. Reboot computer and reinstall per the instructions that came with this network card.
Since you have a cable provider you may have to follow their instructions on setting up a computer for the first time. Your computer might have to send your login and password for you to get internet connectivity. Each ISP is different so its unlikely we can walk you through that.
Old 03-08-09, 01:01 PM
LitUp's Avatar
Well...got the CD-ROM issue resolved by following the tips in this forum post:
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) Barugon’s Cave (^_^)
Soon as headache goes away am diving back into network card issue.
Thanks to all......
Old 03-08-09, 01:49 PM
T
hey, Litup, if this happens again, open your case if you feel comfortable doing so, and make sure the cables to the CDROM are secure.
Mine come out from time to time but I may move my PC more than the average person.... that and my kids bang on it sometimes which I am sure does it no good..
Old 03-10-09, 06:59 PM
LitUp's Avatar
Toofer:
Correct...affected machine is wired
Yep...got lights
IPCONFIG tells me IP address is o.o.o.o
Uninstalled network card via device manager. Fired machine backup and it's still "acquiring network address"
She got new network card, I installed and loaded the driver via CD. Same thing...."acquiring network address". I'm stumped....
Old 03-10-09, 07:27 PM
chandler's Avatar
Do you have the router WEP protected?
Old 03-10-09, 07:46 PM
LitUp's Avatar
Router is WEP or WAP protected, can't remember which.....BUT, wireless laptops connect/function properly. Connectivity is only an issue with WIRED computer.
Old 03-11-09, 08:30 AM
T
Sounds like something is messed up in your TCP/IP stack.
Try this.....
How to reset Internet Protocol (TCP/IP) in Windows XP
Old 03-26-09, 12:50 AM
L
You can try bypassing the router and plugging right into the computer from the modem..
I did something to mine just the same way last week..I can't remember what I did but after a reboot I had the same problem as you..Finally I said the heck with it, reformatted it and as soon as I got to the windows screen I had internet..
Leep:
