Apples to windows
Apples to windows
My daughters Mac notebook was ruined by a renegade bottle of grape soda. We had the hard drive removed and installed in an external enclosure. My question is is there anyway to access the information on the hard drive with a windows based computer
thank you
thank you
If you have another Mac, or know of someone who does, then you can connect that drive to that mac, and network the PC and Mac together to file share.
If you plan on getting another Mac, you can boot up from that external drive by connecting it's external source (USB, Firewire, eSATA) to the Mac, and upon powering it up, hold down the option key. You will then get a selection which you want to boot up from. Select the external drive, and away you go. You can do everything from that external drive as if it was connected internally.
I have bought an external drive just to clone the internal drive (good to have a backup). One program to do clone the drive is called "Carbon Copy Cloner". It is free on the internet, and works well. Again, after the clone, you can boot from that drive.
Good luck,
:rbwest
rbwest pretty much nailed it, however, I just discovered there is an HFS+ viewer available for Windows:
Catacombae - HFSExplorer
This would give you read-only capabilities to the drive. I haven't tested it yet, let us know if it works.
