Switch from Vista 2 XP
Old 09-24-09, 09:47 PM
I purchased a Dell laptop two years ago with Vista loaded on it. Well, I really don't like Vista because of all the hick-ups right now. I wiped my hard drive and tried installing XP. THe installation did not complete because of an error. Is there anything I should do? Am I missing drivers? Is there an issue with loading XP on a box that was configured and manufactured for a Vista load? Any help would be greatly appreciated.
Thanks in advance
Old 09-25-09, 05:36 AM
chandler's Avatar
Received 3 Votes on 3 Posts
What was the error? Did you load from a back up disk or a full load disk?
Old 09-25-09, 02:01 PM
possible SATA driver issue
if the error was SATA related
then you need to have the SATA drivers ( on a CD ) or slip stream the drivers into your XP
XP with SP2 or SP3 will have the SATA drivers intact
or in your BIOS
bios-->system configuration-->SATA Native Support-->changed enabled to DISABLED
then try, sometimes it will work, sometime it will not
have your drivers on a usb or cd for post XP install
especially video, LAN, wifi, chipset
I have converted my 2 year old Toshiba a 215 and a Compaq C700 to XP
Old 09-26-09, 01:57 AM
You need to go into device manager and look up the model number of your sata controller.
Downalod the drivers, and nlite (google it) them into the installation cd, and re-burn.
Then go onto dell and download drivers for graphics etc.
