Need help with selective start-up
Old 10-18-09, 03:12 PM
2x2's Avatar
2x2
2x2 is offline
I need help with doing a selective start-up
I know I can do without the start up items
but what else can I cut that will still allow the computer to function and run faster..?Do I need at least the first three
or first two items I knew at one time but kinda forget
Old 10-18-09, 07:48 PM
2x2's Avatar
2x2
2x2 is offline
selective
yes it looks like it is a must to at least run the first three
Items indicated in a selective start..I have been experimenting
a person can uncheck the start up items only
Old 10-19-09, 05:34 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Defrag the system and empty the cache. Are you running McAfee or Norton? If so, there's your slow up.
Old 10-19-09, 03:16 PM
jmstephens's Avatar
Also if you are running windows XP you can change the settings so as to have less eye candy. It may look like windows 98 if you turn it all off but at least the computer will run faster. I am not sure how much you can cut back on Vista, but I am sure they would have kept this feature in it too.
Old 10-20-09, 11:40 AM
U
Goto Start -> Run -> type "msconfig" [enter]
Disable unwanted or unrecognized junk (check hide all microsoft services) in the "Services" and "Startup" Tab. Reboot PC. Don't worry, your computer should still startup fine even with everything unchecked. You can always go back and re-enable them.
Don't have more than one antivirus / antispyware program. They themselves are giant bloatware.
Old 10-20-09, 12:42 PM
U
If you have lots of RAM, you can turn off Paging.
Right Click My Computer -> Properties -> Advanced Tab -> [Performance] Settings -> Advanced Tab -> [Virtual Memory] Change -> Set to No paging file.
Hard Disk access is in milliseconds, RAM access is in nanoseconds. Go figure However, if you run out of memory, you may BSOD.
Old 10-21-09, 09:09 AM
2x2's Avatar
2x2
2x2 is offline
no paging file
I did this the computer sent a pop up saying I am running out of memory & that I may need to learn how to deal with this..
but thanks a bunch everyone who posted I tried everything mentioned here & it is helping speed the computers up a lot
especially the ones mentioned about msconfig
Old 10-21-09, 12:38 PM
2x2's Avatar
2x2
2x2 is offline
virus program doesn't work
I found my virus program doesn't work
when I put down all microsoft services(msconfig)
it sure speeds the laptop up thou..it's
just that a person needs to restart the computer
again with a normal start if they want to get virus updates and
run the scans
Old 10-21-09, 02:41 PM
U
Well, if you don't have enough RAM (512 mb for the OS + however big your applications are going to be.. so safe bet would be 1Gb at minimum); don't turn off paging. I'd turn off paging if I have 2gb+
As for the virus updates, just find that antivirus service and re-enable it. From that startup tab in the msconfig, expand the Command column (dragging that " | " title bar to the right) and it should roughly tell you what those items are based on directory name. If you use symantec antivirus, then just re-enable the any items with symantec path in it.
Most malware and ad-bots are loaded as startup services, so disabling them will give you a nice performance boost back to normal speed.
Old 10-21-09, 04:02 PM
2x2's Avatar
2x2
2x2 is offline
Ram
I think most folks lack Ram so this idea will never work
turning off paging
Old 10-22-09, 06:53 PM
U
RAM is so cheap nowadays, unless you need super fast RAM for overclocking. I got my 4Gb Ram (DDR2) around ~$20 after $20 Mail in Rebate, and that was 2 yrs ago...
Old 10-24-09, 08:16 PM
You can use the list here to find the necessary start up programs you really need.
Windows startup programs. What are they? Are they required? How can I disable them?
Sysinfo.org
Old 10-25-09, 12:42 PM
0
Programs automatically re enable themselves when run. You need something like startup mechanic to permanently disable them. It also gives a description of each prog for you. Be careful not to disable explorer or your av.
Old 10-25-09, 03:21 PM
some programs will re enable themselves, but most will not.
I have about 25 programs disabled that have not returned on their own.
Old 10-26-09, 05:29 AM
2x2's Avatar
2x2
2x2 is offline
it's much faster now Thanks
Thanks a bunch for everyones help ...I couldn't turn paging files off cause I ain't got a lot of RAM
but I did uninstall all microsoft services and I also have a selective start up in msconfig
Things are much faster now & it's no big deal going to a normal start from time to time if any wish
