Batch File For Copying
Old 11-16-09, 04:36 PM
I'd like to write a batch file to copy certain folders to a USB external drive. I think I can remember enough DOS to write the basic copy commands but since I won't know the destination drive letter until I plug it in, I need help with how to put an "Enter destination drive" command in the routine.
Anyone still speak DOS/BAT?
Old 11-16-09, 06:41 PM
I grew up with DOS but like any language I'm getting rusty.
Anyways, try this. It used to be the CHOICE command but now in XP (don't have Vista or 7) it's called SET.
You can use this to copy files to existing folders as well. Whatever you put in for the prompt is where it will copy the files too.
___________________________________________
ECHO.
ECHO File Copy Utility
@ Echo off
rem *** the next line will clear any current variable ***
set choice=
rem *** this next line prompts for input and sets variable ***
set /p choice=Enter Destination Drive letter:
copy c:\test\*.* %choice%
Old 11-17-09, 09:21 AM
That should work.
Thanks dan
Old 11-22-09, 08:04 PM
Just a side note (since your question was answered): you may want to use Microsoft's free utility called Robocopy to do this. It is command line, and VERY much more powerful than copy or xcopy.
My favorite feature of robocopy is it's /MIR switch, which is great for backups as you can maintain a MIRror image of a folder in a backup location...first time, it grabs everything, from then on, just what's changed...careful though, if you delete from the source, it deletes from the destination.
Old 11-23-09, 10:45 AM
There can never be too many answers :-)
Thanks chirkware.
