Brother MFC-490cw not working with Windows 7
Old 12-31-09, 09:36 AM
N
I use an HP Pavilion dv6000 laptop as my primary computer at home with a Linksys WRT54g wireless router. I had been using a Brother All-In-One (model MFC-490cw) wireless printer, but I have not been able to print from this computer since upgrading from Vista to Windows 7. I know the issue is not with the printer or the router, because I also have an older Compaq laptop on my wireless network that is running XP, and I have no problems printing from that computer.
I tried reinstalling the drivers from the original printer CD, but get an error message saying they are not compatible with my operating system. I downloaded Brother's Windows 7 drivers and installed them at least a half dozen times now, but no go. The printer is shown as being on line and ready, but whenever I try to print something, my document ends up in the print queue but never prints.
Old 12-31-09, 01:32 PM
Received 98 Votes on 86 Posts
Have you contacted Brother?
I can see needing a new driver, but you did that so my next step would be to call them.
Old 12-31-09, 02:22 PM
crazycory22's Avatar
Received 1 Vote on 1 Post
Is it 7 64bit or 32bit? Windows 7 64bit doesn't like drivers of some variety, and also it could be your printer just isn't compatible with Windows 7. I had that problem with a wireless device about a month or so ago.
Old 01-01-10, 04:51 AM
N
It's the 32-bit version. I went to the Brother web site, which says this model is Win7 compatible, and downloaded what they said was the correct driver. Also contacted them via email, but the response I got was for this model not working with Vista, which it did just fine before I upgraded.
Old 01-01-10, 05:02 AM
GregH's Avatar
Super Moderator
Received 54 Votes on 50 Posts
First I would suggest that you uninstall all drivers for that printer then download the correct driver.
Make sure that you are downloading the 32 bit version.
Old 01-01-10, 05:46 AM
N
Having already done that, more than once, what would be your second suggestion?
Old 01-01-10, 07:25 AM
GregH's Avatar
Super Moderator
Maybe the laptop can not see the printer on the network.
Go to network connections to see if you can see it.
Old 01-02-10, 05:37 AM
N
If the network isn't seeing the printer my second laptop, the one running XP, would also not function, but as mentioned previously, I have no issues printing from that machine.
Old 01-02-10, 09:43 AM
GregH's Avatar
Super Moderator
No, if the printer is on a wireless network the computer you are trying to print from must be able to see the printer.
On Win7 go to control panel > network and internet > view network status and tasks.
Under Active Networks you should see the router and the printer.
If you do not see the printer select "connect to a network" and see if the printer shows up.
Old 01-02-10, 11:45 AM
N
I'm sorry, but if the printer shows up in the control panel as being on-line and ready, as stated in my original post, does that not mean the computer sees it? I mean, if the laptop didn't see the printer, I would be getting an error message to that effect, would I not?
