Looking for info on ram for my pc
Old 01-02-10, 03:24 PM
PRO1 TECH's Avatar
HOW CAN I FIND OUT THE MAX OF RAM I CAN INSTALL IN MY UNIT
Old 01-02-10, 04:03 PM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
Go here....very accurate and easy. RAM Memory Upgrade: Dell, Mac, Apple, HP, Compaq. USB drives, flash cards, SSD at Crucial.com
Of course you don't need to buy theirs..you can get it wherever.
Old 01-02-10, 04:04 PM
chandler's Avatar
Received 8 Votes on 7 Posts
Old 01-02-10, 08:04 PM
PRO1 TECH's Avatar
how do i find out this info
If you are using a 64-bit operating system your computer will support a maximum of 8 GB of memory.
If you are using a 32-bit operating system, your computer will only support a maximum of 4 GB of memory.
Modules must be ordered and installed in pairs for Dual Channel Mode
Old 01-03-10, 06:34 AM
W
Received 36 Votes on 33 Posts
Processor
Go to: My Computer-->View System Information
Old 01-03-10, 12:34 PM
PRO1 TECH's Avatar
more info i installed 2 2gb ddr2 dimm and the system tells me 3gb
and this what dell tells me is in the system
BIOS Vendor Dell Inc.
BIOS Version 2.5.0
BIOS Date 05-24-07
Windows Version Microsoft Windows XP Professional
Processor
Manufacturer Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz
Clock Speed 1.9GHz
L2 Cache Size 2048
Processor
Clock Speed 1.9GHz
Memory
Available Memory 74.11 %
Page File Size -1021.Mb
Available Page File -1050 %
Virtual Memory 2047.8Mb
Available Virtual Memory 98.01 %
Memory Slot 1 [DIMM_3] 2048Mb
Memory Slot 2 [DIMM_2] 2048Mb
Memory
any help
Old 01-03-10, 01:10 PM
nap's Avatar
nap
nap is offline
New Member
Received 1 Vote on 1 Post
where does that say anything about 3 gig of memory. It clearly states you have 2 X 2 gig of mem installed.
Memory
what "system" is telling you 3 gig of anything?
Old 01-03-10, 01:49 PM
PRO1 TECH's Avatar
Old 01-03-10, 02:12 PM
PRO1 TECH's Avatar
just found out why
Why doesn't my Windows® PC recognize the whole 4GB of memory I installed?
Not only is there a maximum amount of memory that your computer motherboard can accept, there is also a maximum amount of memory that your operating system (OS) can accept. For instance, when you install 4GB of memory in a 32-bit Windows system (the most common version; 64-bit systems are typically used by high-end users), your system reports only 3GB or 3.5GB.
First , we can assure you, there isn't a problem with the memory. While Windows allows for 4GB of memory to be addressed, it does not equate to 4GB of physical memory.
Some of the memory (regardless of how much you have installed) is reserved for use by the devices that you are using, such as a graphics card, PCI card, integrated network connections, etc, meaning it is unavailable for use as normal main memory.
Upon startup, your system calculates the amount of memory needed for these devices; if you haven't maxxed out the memory in your system, it's invisible to you, and all your physical memory (the installed RAM) is available for use. However if you've maxxed out the DRAM in your system, this amount will be deducted from your physical memory, so you can't use 100% of your DRAM.
The maximum memory limitation varies by operating system, For instance, the 4GB memory limitation doesn't exist in 64-bit versions of Windows.
Q: Will my system recognize the maximum upgrade?
A: Possibly
How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS. More information about OS memory maximums can be found at Crucial FAQ - Answer.
