Computer won't boot
Old 03-18-10, 11:51 AM
E
Computer won't boot
I bought a new computer, and just set the old one off to the side. It worked fine went I stopped using it, it was just old and slow, and I needed more speed, and power. The other day I turned it on to get some files and pic off of it, and it won't start. I get a error message, the says the operating system is gone. I pulled the hard drive, and put it in a external hard drive case. And all it does is run a click. Any ideas
Old 03-18-10, 03:19 PM
A
Dust
I am not expert, but it sounds like it may be a dust issue.
I have had a few issues with dust and computers in the past.
Make sure you open your CPU in non-dusty environment (as much as possible).
Old 03-18-10, 04:07 PM
If you pulled the hard drive and put it in an external housing hooked to another computer and it still is not doing anything I would say the drive has died. Does the computer you have it hooked to, I'm assuming via usb, see it?
Old 03-18-10, 05:09 PM
mickblock's Avatar
What kind of connection are you using?
Old 03-18-10, 06:14 PM
E
Yes it is a usb. The drive makes the normal start up noises, the real fast clicking, and a couple buzzes, then is just keeps on clicking, but not as fast the start up clicking.
Old 03-18-10, 06:32 PM
Tolyn Ironhand's Avatar
Received 207 Votes on 184 Posts
If you have a boot disk you can go into the BIOS and change the boot order to boot to your CD drive. To enter the BIOS perss F2 or delete while it is POSTing. It does POST right?
Old 03-18-10, 09:11 PM
E
Iam using a usb connection
