Card Reader Disappeared?
The memory card reader on my computer is no longer visible. Normally when I look at "computer" I could see drives C through I. Today I can only see drives C, D and E. The missing drives are all the slots of the memory card reader. How can I start narrowing down if this is a hardware or software problem?
My computer is a Dell i530-111B running Windows Vista. The problem started sometime between tonight and last night. There was no change in the problem after restarting the computer.
Does it show the USB hub that the reader is connected to?
If so...I'd just delete it in device manager and let it reinstall after a restart...
Make sure any connector cables are firmly seated also..
It may have just failed. My SATA controller recently just failed on my MOBO. Which was a bummer because I thought my drive failed.
Can only run IDE now. Stupid 80GB drive.
Maybe just pickup a USB card reader.
Thanks for the tips. It's my home computer so it will be this evening before I can check.
My card reader has 2 USB ports. When I run a cable from the USB port on the card reader to my camera I can see the folders on the CF card but no files inside. When I use Windows Explorer I can see and copy the pictures so I think the USB portion of it is working.
Received 0 Votes
Have you tried doing the scan for new hardware? I think it comes up as an option on the right click of the device manager. If the PC just lost it then that might make it find it again.
Thanks for all the help. I unplugged the card reader and plugged it back in and now it works. Probably just a loose or corroded connector.
Who knew fixing a computer would be like working on a 1960's British sports car.
Never go anywhere without a buddy (in another car) and a hammer. The hammer to pound on the starter, solenoid and anything else that looked electrical and the buddy to give you a ride home.
Previous Thread
Next Thread
