HP Photosmart Premium -- Copier problem
Old 08-24-10, 01:56 PM
The HP Photosmart Premium unit (printer/fax/scan/copy) will print out documents (in b/w) sent from the computer but it will not COPY documents... User guide is useless .... Any ideas what is going on?
Thanks
Old 08-24-10, 02:57 PM
HotxxxxxxxOKC's Avatar
Load the paper to be copied onto the scanner bed, hit COPY on the home screen, then the right arrow button to select # of copies, then hit the B/W or Color Copy button?
Are you doing all these steps and it's still not working?
Old 08-25-10, 06:14 AM
The feeder is also not working... I had been opening the top and doing one sheet at a time but that is not working now. I am also making sure that the top is closed before I try copying.
Old 08-25-10, 06:47 AM
If this device is brand new, did you remove all the protective tape from inside the unit? You would normally lift the top half of the printer and pull some tape. Kind of like step #3 in this manual:
http://bizsupport1.austin.hp.com/bc/.../c01659736.pdf
Old 08-26-10, 12:19 PM
Thanks
I have owned the unit for a year or so and have in the past been able to make copies. The new problem has just recently surfaced
Old 09-02-10, 10:03 PM
kevinfathom's Avatar
Smile
Contact HP's customer support for assistance. Or bring it to the nearest service center.
