Help
Old 09-19-10, 02:27 AM
Help
My laptop, HP G61-631NR notebook. It wont start windows, the message is windows boot manager, File:\boot\BCD , Status: 0xc00000e9 , Info: an unexpected I/O error has occurred. It say it happened when i was downloading photos from my phone. It states that I need to reconnect my phone to it would work it doesnt, how can I get around this to get it going again?
Old 09-19-10, 11:57 AM
HotxxxxxxxOKC's Avatar
Not good.
I had this before and it happened when the boot configuration files were corrupted. I ended up having to do a complete drive wipe and reload.
Here's a list of things you can try, though.
Method 1: Startup Repair from the Windows Recovery Environment (WinRE)
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD …". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. Click the operating system that you want to repair, and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Method 2: Rebuild BCD
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type BOOTREC /FIXMBR, and then press ENTER.
8. Type BOOTREC /FIXBOOT, and then press ENTER.
9. Type BOOTREC /REBUILDBCD, and then press ENTER.
Method 3: Use the Windows Recovery Environment (WinRE) to run System Restore
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Old 09-20-10, 06:50 AM
It has windows 7, I only have a repair disk but when I put it in I keep getting the same screen.
Old 09-20-10, 10:25 AM
Have you tried Method #2? You will first have to go into your BIOS as soon as you turn on your machine and ensure the computer boots from the CD ROM drive first, making it your first priority boot sequence.
