Defrag in Safe Mode
Old 01-05-01, 06:31 AM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
I heard that you can defrag a system in safe-mode, much faster then in normal-mode.
My question is, how do you reboot the computer into safe mode? or exit normal-mode onto safe-mode?
What are the key strokes?
Running Win98
Plumber2000
Old 01-05-01, 07:17 AM
A
Received 1 Upvote on 1 Post
If I remember right, you hold down the F8 key when the windows startup screen appears. This will take you to a menu, with an option of starting up in Safe Mode. Scan Disk also runs much faster in Safe Mode.
Old 01-05-01, 07:20 AM
A
If you go to Start - Help, and in the Index, type SAFE, it will take you to detailed instructions on startup in Safe Mode.
Old 01-05-01, 07:29 AM
Found it, thanks, F8 was not it, it's CTRL key.
Tried the F8 key after your 1st post and all it did was beeps at me.
Plumber2000
