Are all parts compatible on this DIY computer build?
Old 09-30-11, 02:00 PM
B
Just wondering if anyone knows if all parts below compatible with each other or not:
CPU Intel Core i5-2500K Sandy Bridge 3.3GHz
Newegg.com - Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
EVGA SuperClocked GeForce GTX 570(Fermi)
Newegg.com - EVGA SuperClocked 012-P3-1573-AR GeForce GTX 570 HD w/Display-Port (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Motherboard ASUS P8Z68-V LE LGA 1155 Z68 HDMI SATA 6 ATX Intel
Newegg.com - ASUS P8Z68-V LE LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
Or this motherboard:
ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel
Newegg.com - ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
G.SKILL Ripjaws X Series(2 x 2GB)
Newegg.com - G.SKILL Ripjaws X Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBXL
HDD Western Digital Caviar Blue WD3200AAKX 320GB
Newegg.com - Western Digital Caviar Blue WD3200AAKX 320GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Case Rosewill Smart One ATX Mid Tower Computer $40
Newegg.com - Rosewill Smart One ATX Mid Tower Computer Case, Black interior, comes with three Fans-1x Front Blue LED 120mm Fan, 1x Rear 120mm Fan, 1x Top 120mm Fan, Option Fans-2x Side 120mm Fan
Power Supply CORSAIR Enthusiast Series CMPSU-850TX 850W SLI Certified (Getting this cuz I might get a 2nd video card, so that will be good enough right?)
Newegg.com - CORSAIR Enthusiast Series CMPSU-850TX 850W ATX12V v2.2 / EPS12V v2.91 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply
Please let me know if all parts compatible with each other or not?
Old 09-30-11, 03:40 PM
chandler's Avatar
Received 9 Votes on 8 Posts
I hope you get a satisfactory answer. You are pressing the limits of DIY. How much money will you have invested in all this as opposed to buying a big bad computer?
Old 09-30-11, 04:00 PM
H
I found your motherboard on the manufacturers website. When I put in my MSI 785GTM-E45 into my new computer case a few months back I looked at their website to see about compatibility issues and ASUS will have the same kind of information. One tip I will give you when connecting the on/off switch and other things be sure to make sure what is on the motherboard lines up with what is in the instruction booklet. In my booklet it was upside down to what was on the board. Here is the link you need ASUSTeK Computer Inc. - Motherboards- ASUS P8Z68-V PRO Good luck to you!
Old 09-30-11, 06:19 PM
Tolyn Ironhand's Avatar
Received 597 Votes on 512 Posts
Did you happen to see your other post here: http://www.doityourself.com/forum/co...ml#post1887768
Biggest compatibly issues will come from MoBo and RAM. Check them out and you should be fine.
A 320 GB HD?? I would go a 500 GB minimum. 1TB would be better.
Old 09-30-11, 06:35 PM
Z
Received 87 Votes on 81 Posts
Also I was wondering about the 320GB HDD. Might be a little skimpy for a high powered system like that. Looks like the 500 GB is only 10 bucks more.
Old 09-30-11, 11:11 PM
F
Received 36 Votes on 28 Posts
What do you people do to use so much hard drive space? I have a 68 G drive with 58.9G free.
Old 10-01-11, 06:01 AM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
All depends on the usage Furd. My garage PC is pretty much like yours....80G with something like 64 free...and thats probably cause theres a lot of junk still on it. Wifes PC (before the melt down) had a 250g with only about 30 free....she has a lot of music and thousands of pics on it. If someone had pics, movies, games, music, plus all the programs....I can see how it could start filling up. Her new one has 1T on it....
Old 10-01-11, 10:28 AM
Games. A system like the one posted is even newer, better, faster then mine. I have a 120GB SSD for the OS and other operating things (of which 53GB is free) and then I have 2 - 1TB drives. One for storage of games, pictures and everything else and the other is my backup drive in case the first one fails. My storage drive has 214 GB used up. Its all what you use it for.
Old 10-01-11, 11:35 AM
Spikester's Avatar
Also depends on what all you actually use the system for. My desktop runs virtual box with a lot of virtual machines. My data usage between all drives is probably around 2 TB out of around 3 TB of actual storage space between both systems and external drives. That also includes backup ISOs of all of my discs, system images, pictures, music, Linux ISOs, as well a couple hundred GBs of Open Source Software. Given some of the stuff is duplicates due to backups though. I also system image some of my clients' PCs as well. This can easily fill a 1TB drive in a few days. Also on both desktop and laptop I triple boot operating systems.
Old 10-04-11, 05:34 PM
B
Thanks for all your replies and I was able to figure out the exact parts to get with some other forum members help!
