recording on ibm netvista
Old 01-11-01, 08:52 PM
Guest
I have a netvista IBM with a cd-rw drive. It's using
a program called adaptec create cd, 4.02s. I recorded three music disk, but now it's recording a few songs, then spitting out the cd, saying there's not enough disk space
on the cd to finish. I've messed up about 10 disk, so i went to erase them and find I don't have a start button on the erase cd option. Any help?
squirtm
Old 01-12-01, 05:01 PM
Guest
Hmmm, sounds like your using cdr disks, that's why the erase button is not available. Make sure you have the right type of disc, either cr-rw or cdr.
You can try here for some adaptec help
http://www.roxio.com/en/support/
You can also go here and update your aspi layer which is good but probably not the ansert to your problem.
http://www.adaptec.com/support/faqs/aspilayer.html
I have never seen that error before, it may have to do with the blanks you are using.
