Opinion
Opinion
I have been working on a friends computer which received a virus. (He removed his antivirus temporarily due to an install issue and forgot to reinstall it) Got the virus removed but things are still mucked up. I can use it, run programs, and browse the Internet. (Although I have not done any of these for any length of time.) I can't however update Windows, do a system restore or even do a repair install using the XP disk as it does not even see the drive!? Also doing a scan with Malwarebytes causes a BSOD.
So at this point I'm looking at a backup, format, and reinstall. Wondering if just upgrading to Windows 7 would make sense and if the Windows 7 install would fix the underlying issues and avoid the full rebuild?
Opinions?
Opinions?
While I find upgrading fixes a host of problems, the problem you have now is that you can't upgrade to 7 from XP. You'd need to upgrade to Vista first.
eta, if XP can't see the drive, then another OS may not see it either.
Received 0 Votes
Well I beg to differ Shadeladie you can upgrade to Windows 7 but you need to wipe the drive first providing of course that the computer meets all of the requirements for Windows 7 such as memory. I agree with you though installing another operating system probably will not solve any problems and since Windows can't see the drive in Windows XP I doubt Windows 7 will either. Not sure about Linux though and I am no expert about that as I have never tried the program but know that Linux works differently. I also understand you can have dual operating systems but I have never done that before either. With the problems you are having though Tolyn I think your idea of just wiping the system is really best. I think the virus really did a number on the computer and to really get it back to where it was before it needs to have the hard drive wiped. I think your friend would like that better too. As for copying some of the files on the computer I strongly suggest you check those files with another anti virus before allowing them back on that computer. Good luck!
Thanks for the input!
I do know you can't do a seamless upgrade from Xp to Win 7 but MS has some tools to save your settings to do the transition.
I did make sure that the DVD/CD drive is set to first boot. To be clear, XP boots up and runs. I go through the steps and it asks me what drive to instal it to but it shows no drives!?!? I might still try a fixmbr.
Combofix is one that I saw but did not try. I will give it a whirl.
No. It displays the available drives, of which it shows none. When I had a USB stick attached, it did show that.
Update: I did try the Combofix Rick posted and that has seamed to fix the windows restore and update issue. This is the best progress I have made lately so things are looking up.
Also, see above post.
All of this being said, with that bad of an infection, I would cut the losses, backup, and do a format and reinstall. Be the best option to fix all of the issues. Also why did he ever uninstall his AV? He could have simply disabled it for the time being for an install issue.
Hope this helps.
~Spike
