Help, unable to find usb flash drive in my computer
Old 03-12-13, 02:54 AM
R
When I plug in a flash drive stick the F drive never comes up ? Any suggestions ? Thanks in advance.
Old 03-12-13, 04:31 AM
the_tow_guy's Avatar
Received 55 Votes on 45 Posts
I'm assuming you've already used the stick elsewhere and it's working? First thing, have you tried plugging another device in to make sure the usb port is working? Second, right click on My Computer then click "Manage". Click Storage and Disk Management. Check to see if the drive is shown.
Old 03-12-13, 04:55 AM
Received 94 Votes on 83 Posts
I've had this happen before and each time the solution was to plug it into a different USB port on the machine. The drives can go bad, I've just had ports go bad instead.
Old 03-12-13, 07:30 PM
H
If you are plugging the USB drive on a USB hub then I would try using the USB drive on the computer itself. Sometimes the hubs go bad too so try the USB drive in another computer or another USB port on the computer itself. Sometimes too just restarting the computer solves the problem.
