Can't get Windows Updates
Old 04-08-13, 06:22 AM
Windows 7
I suspected I wasn't getting Updates. Went to "Fix It", and it found (and corrected) two problems. Alledgedly.
So I went back to Updates and hit "Check for Updates". It said "Cannot check for Updates because the service isn't running. You may need to re-start your computer."
I re-started. (Again) And I still get the same message.
Now what?
Old 04-08-13, 09:01 AM
the_tow_guy's Avatar
Received 29 Votes on 23 Posts
Check services to make sure it's running?
Old 04-08-13, 09:53 AM
Did I fail to mention that I'm not very bright? How do you check "services?"
Old 04-08-13, 02:33 PM
Louuuu in Windows 7 type services into your search area and look for services in Control Panel.
Old 04-09-13, 04:32 AM
Thanks. 'Found it. Under "status" it says 'started'.
So I went to Updates, clicked on "check for updates", and got the same error message noted in the original post...
Old 04-09-13, 04:49 AM
You might try this, it is one of many suggetions I found when googled your problem.
Besides Windows Updates you also need "Background Intelligent Transfer Service" to be started.
You can either set it to Automatic or start it manually and then try to download the updates.
If it still doesn't work then try microsoft fixit
How do I reset Windows Update components?
Old 04-09-13, 06:27 AM
Thanks.
Background Intelligent Transfer Service was "started" already.
Microsoft Fix It claims to have repaired two items, but even after restarting, I'm not seeing anything different. Same error message.
So I'm back where I started....
Old 04-09-13, 06:32 AM
I have ran into that problem several times in windows 7, has always been a different fix.
Did you try the "let me fix it myself" instructions? here:
support.microsoft.com/kb/971058
Old 04-09-13, 08:07 AM
Thanks. I will.
But the way this day is shaping up, I may not get to it 'til tomorrow. Stay tuned.
Old 04-09-13, 01:56 PM
Louuuuu I did a little bit of research myself it seems that there is another bit of software besides Fix It that works automatically here is the link to that Windows Update error 80072efe or 80072f76 . When you go to that page you will see outlined in blue automatic troubleshooter click on that and a download will pop up, run the program and hopefully everything will start working. If that doesn't work there is a line of code that you can run from the Microsoft answers forum here is the link to that windows 7 automatic updates wont run, error 8024800A - Microsoft Community . Go down to where it says Most helpful Reply and follow the instructions. I never have had problems with updates in Windows 7 Windows XP plenty of problems but so far none with Windows 7. I never have tried this solution on the answers forum but many of the solutions there usually work. I don't guarantee that it will work as I have no experience with it so I would try the download first. Good luck to you!
Old 04-10-13, 05:26 AM
We have a winner!
It appears that I have a fully updated computer now.
The links to the MS website didn't directly result in a repair. However, one of the forums there mentioned another website that had "The Fix". Something about deleting the contents of all the update-related folders (because one of them was corrupt) then re-activating Updates.
Thanks.
Old 04-10-13, 05:37 AM
Great!!! Glad that you now have it!
