Network problem
Old 04-18-14, 06:03 AM
Geochurchi's Avatar
Received 65 Votes on 61 Posts
Network problem
Hi All, I have an ipad 2 which works fine on my network I have other unsecured networks that show up on ipad and override my network, yet I can't connect using them,what's up with that?
Thanks
Geo
Old 04-18-14, 06:13 AM
P
Temporarily Suspended
Two possible reasons are you are out of range or MAC filtering is enabled.
Old 04-18-14, 08:10 AM
Geochurchi's Avatar
Seems like the signal is strong enough,how do I check the Mac setting?
Geo
Old 04-18-14, 02:18 PM
That's not something that would be on the ipad, it's a setting on the routers/APs of the unsecured networks. I assume you don't own them?
Basically this is a result of Apple's overly simplifying things. There is no real way to create a preferential order for the WiFi networks in an iOS device like you can on Android, Windows, etc. If more than one remembered network is available, it simply connects to the one that's first alphabetically.
There's a workaround though.. Go to Settings > Choose a Network > Select the blue arrow by the network you do *not* want > At the top of the page it says "Forget this network" - select this > tap 'Forget'. Repeat for the other one. Then go back to the Choose Networks page and turn OFF the "Ask to Join Networks" option. That will keep it from bugging you to join the open networks - but it means you will have to go in and manually join a new network if you bring it to a new place.
Old 04-18-14, 04:51 PM
P
MAC filtering is done to stop you from connecting, to their network. You can't change it.
Old 04-19-14, 05:28 AM
Geochurchi's Avatar
Good information,thanks
Geo
Old 05-05-14, 05:08 PM
Geochurchi's Avatar
Wifi connection issue
Hi All, I was staying in a hotel this week and could not get on to their there free wifi with the provided password using my ipad ,upon contacting the front desk they told me to sign into a website I had recently used and I should be fine,and believe it or not it worked,they said that Apple products often times keep refreshing Google or other search engines which appears to be the case as the little wheel just kept spinning and never connected.
Thoughts
Geo
