How do you use Intel’s VT-d ?
Working recently in my laptop I noticed in the BIOS the entry “VT-d” (Enabled) and searching I found this entry is for the Intel’s virtualization technology for direct I/O
I use VMware to run XP Pro in my Windows 8.1 laptop but can I use the VT-d to do the same?
If not, is there any benefit to disable the VT-d ?
Temporarily Suspended
https://software.intel.com/en-us/art...-of-io-devices
According to that site VT-d enhances the performance of VMWare or whatever VM software you use by regulating DMA. That's direct memory access. It is not a separate program that's used in place of VMWare. If you disable it, your VM may not run as well.
AFAIK, it's of no benefit to anything that doesn't require it, and XP does not require it. And unless I'm mistaken, Win8.2 (sometimes euphemistically referred to as Win10) is the first Windoze OS that won't run in any virtual environment that isn't supported by either VT-x or AMD-V.
I don't think it's a question of what's running inside the VM. It's a question of how the VM, itself uses the input output & memory. In Kolia's case, it's VMWare. In other words, it's VMWare not XP is running, in the sandbox. VT-d is basically creating the sandnox. If you need an explanation of sandbox, either let me know or do a Google search for sandboxie. That's a proprietary sandbox that's used with Windows.
I found the same link Pulpo but was too complicated for my and that's why I post the question here. The way I understand now I better leave the VT-d enable as it is from factory
