Lost Data Recovery
Lost Data Recovery
Are there any programs that can recover lost data from an Excel Spread sheet?
Part of spread sheet was being worked on, date either lost or not saved/
Tried all the listed MS and Win fixes
Look in the folder where the spreadsheet was saved. Set the folder to view all file types including extensions. You may get lucky and see backups with a tilde (~) in the almost-identical file name and/or ".tmp" as the file type. If they aren't there, try searching the C drive for files with a .tmp extension, and a second search for the tilde.
right click the file and go to properties... select the tab that says previous versions. depending how much memory you have allocated for restore, it may have more versions stored.
