Caps Lock problem
Caps Lock problem
I have a Microsoft keyboard that was working fine for the fast few years.
Suddenly the Caps Lock key works in reverse.
When the indicator light at the top right appears as in capitals mode, the lower case is written- and when it should be in lower case mode the upper case is written.
Ghelp
Ghelp
I think that I just solved my problem.
What I did?
I pressed the Caps Lock key and held it down for a while.
I noticed that the light strobbed ( blinked fast ).
When I released it I was back to normal.
Ghelp
What I did?
Ghelp
And I just deleted my caps lock key from the list of keys so pressing it does nothing. No more accidentally typing in all caps then having to go back and correct. (Yes, I watch my single digit on the keyboard not the screen when I type.)
