Web Monitor Temperature
Is there a way to remotely web monitor temperature of a home? Imagine being in FL for the winter and the home is in Iowa where the temp is below zero and the furnace fails for some reason other than a power failure. Primarily concerned with frozen water pipes.
most any wifi thermostat will display the current temp in your house on your cell phone or computer. Some even send you a warning email if the temp gets too low.
As for thermostats I believe I saw a round thermostat on Ask This Old House made by Honeywell that has wifi. If you are concerned about flooding I know I have heard of monitors that will tell you if you have a water leak unfortunately I don't remember any names. They also make emergency shutoff valves that when they detect a leak they automatically shut the water off and some of those may be monitored too. The wifi thermostats work reasonably well but I have heard mixed reviews of the other things I mentioned.
Of course the Iowa home would need to have a wifi network active while you are away. Many ppl shut down cable and landlines when a home sits vacant for months.
The "old school" method is to ask a neighbor to check on the house. There are thermostatic switches that will turn on a lamp in the window if the temp falls below a certain point.
I wish I had done that at my cottage before my boiler quit sometime in February causing my pipes to burst and pump split in half. Hindsight you know...
