Two folders have same exact files, but one folder is larger than the other one.
I do backups on multiple hard drives, and i occasionally right click and check properties to make sure everything is 1:1 copied. I get them perfectly matching, yet every time i go back and check them after a few months there are discrepancies in different areas.
For instance if i right click on a folder, it will show 6 files and 132MB. When i right click on it's counterpart it shows 7 files and 132.7MB. Each folder only has 6 files, and they are all the same exact size... yet when i check the properties on one of them, it shows more files and data.
The option to view hidden files and folders is selected on each folder.
Here is a picture of both folder properties:
http://i.imgur.com/X0AQGdX.png
Here is a list of the contents of each folder:
http://i.imgur.com/oNHLfDM.png
As you can see, the contents are exactly the same, yet one folder shows more than the other.
Any idea as to why this is happening? I always end up deleting one of the folders and making a copy of the remaining one, because that's the only way i can get them to match 1:1. Would really like to find out why it keeps happening, because it gets tedious.
Win10
Win10
Do you have "hide protected and system files" checked? Try unchecking that. It may be a thumbnail file that the OS generates for a thumbnail view of the folder.
Temporarily Suspended
Are all the drives formatted to the same file system, say NTFS? I've seen size differences if I list the contents of a directory, in windows explorer & if I list them inside a command prompt. That's the same file, on the same drive.
The only time its a problem is if a virus attached itself to an exe. Then the size difference might mean something. Taking it a step beyond that, when you download something, you might be given a checksum, md5 or sha1. That way you can verify if someone tampered with it.
CarbideTipped
I'm now disabling the creation of those thumb files, so this doesn't happen in the future.
Thanks.
