JavaScript?
Old 04-22-16, 04:00 PM
Handyone's Avatar
JavaScript?
Any idea why I can't register at a web site? I'm using windows 7 64bit.
I tried explorer and chrome, neither work.
I fill out the form which is boring, it's a financial site.
Everything is normal, including going to other sections, until I need to click on submit. The submit button looks like it should be highlighted more, or a little darker, and doesn't respond.
I gave up starting over.
Old 04-22-16, 05:04 PM
Shadeladie's Avatar
Super Moderator
Received 179 Votes on 145 Posts
Have you tried Firefox? When those 2 don't respond to something, usually FF does. Some sites are optimized for one browser over others.
Old 04-22-16, 05:29 PM
Received 1,616 Votes on 1,488 Posts
Usually if it's a JavaScript problem the website will inform you that it is required if it doesn't see it running in your browser.
I don't allow Java to run unless I tell it too.
Old 04-22-16, 06:01 PM
Norm201's Avatar
Received 376 Votes on 341 Posts
If you try Firefox, be sure get the add-on called Fire IE.
Old 04-22-16, 07:11 PM
P
Temporarily Suspended
Usually if it's a JavaScript problem.........
Java & Javascript are two different things from 2 different companies.
Handyone, I know that it's boring but are you sure that you are completing all the required fields? Required fields sometimes have red astericks next to them. I have a feeling that's why the submit button is not responding.
Old 04-23-16, 05:49 AM
chandler's Avatar
Received 8 Votes on 7 Posts
Firefox and Java Script don't play nicely with each other. I use Network Solutions for my websites and make updates and changes occasionally. I have the same problem with Firefox in that the "publish" button is grayed out. I have to switch to Chrome to get it published. Last time, I didn't want to switch browsers and do it all over again, so I called NS and they published it for me and supposedly installed something on their site that allowed me to publish. We'll find out next time.
