combining pics to common folder & sorting duplicates??
Old 02-11-17, 05:53 AM
I have a ton of pics on various different drives and computers. I would like to be able to combine and back them all up to one common place. Is there a way to sort out pics that are duplicates even if the file names might be different? What is the best way to do what I am wanting to do? thanks
Old 02-11-17, 06:55 AM
Received 49 Votes on 42 Posts
Well, the simplest way is display them as large thumbnails and sort them by size.
Given how cheap storage is, I'd just copy all the photos into a folder on a drive,
then run any of several de-duplication programs to identify the duplicates.
Old 02-11-17, 08:01 AM
GregH's Avatar
Super Moderator
Received 19 Votes on 19 Posts
You will find that if you put all the files into one folder and use the list view, unless something has happened to the files it will sort them by date.
Old 02-11-17, 08:55 AM
Shadeladie's Avatar
Super Moderator
Received 69 Votes on 55 Posts
I recently bought a 64Gb Flash Drive to copy files and pics from an old computer to a new one, for under $20. Just mentioning this because you can easily copy everything from all your various places to one place with this.
Old 02-11-17, 09:52 AM
You really didn't need a flash drive to transfer files from on PC to another, if they are both on the same network. It's much faster to map the drive from one PC to the other. In both cases, Microsoft Sync Toy may help. Use wired connections when possible. Transfers are much faster & can be done in seconds.
Old 02-11-17, 10:34 AM
Received 18 Votes on 13 Posts
^^^^^^ This right here ^^^^^^
Old 02-12-17, 06:09 AM
Norm201's Avatar
Received 121 Votes on 111 Posts
You can also used something like Dropbox as a repository. This will hold them and prevent accidental erasure as you sort between the two drives.
Old 02-12-17, 09:41 AM
Good point.
IIRC, both Google Photos and Amazon Prime Photos both offer free unlimited photo storage.
So, setup an account, upload the pictures from computer #1, #2 etc.
Then they're all backed up.
I think that Google includes automatic organization, and grouping, which should help with de-duplication.
