Graphics Card
Graphics Card
I have a HP Pavilion 6720f CPU running Win 10 that the graphics went south on the motherboard. I purchased a Nvidia GeForce 8400GS pci graphics card from Amazon and installed it. I can't get my monitor screen to center. It shows up to the right. It will not recenter automatically, so i tried to do it manually. It will not center. When I use autocenter function on the monitor, it goes back further to the right. I'm wondering if the graphics card is bad. Anyone have ideas????
Received 0 Votes
It sounds like Windows defaulted to a wonky resolution instead of auto-detecting the monitor's native. What is the monitor brand/model number? Is it connected via HDMI/DVI or standard VGA cable?
Basically click your Cortana bar and type RESOLUTION (or if Cortana is set up for voice, say "Hey Cortana, change my screen resolution"). The first option will be "Change the display resolution". You need to go into that and change it to whatever the monitor's native is. Usually will be 1920x1080 (full HD display), 1680x1050 (lots of 20-24" displays), or 1440x900 (17 and 19" displays).
Graphics card
It's pretty crazy, but I switched out CPUs. Mine is a little older than hers. Her monitor works fine (27") showing everything that it's supposed to. Her's, with my smaller monitor is working fine. I still can't figure out what the problem is, however, I'm leaving everything alone for now. Thanks for the input. Dinky
Received 0 Votes
Um, I think he was talking about swapping the entire tower. That's what most tech-nots are referring to when they say "CPU".
And the fact that they both work on the other's monitor makes it more obvious that it was just a resolution issue.
